Pull-up resistor on the D+ and D- lines of FX2LP CY7C68013A
XiangyangZ_06
First like received Welcome!
Question: Do I need external pull-up resistors on the D+ and D- lines of FX2LP CY7C68013A?
Answer:
No, you don't need to add a external resistor on D+ and D- lines. CY7C68013A has a internal pull-up resistor for USB device identification.
Contributors
