Programming the CY22150 with FPGA
12:00 AM
- Mark as Read
- Printer Friendly Page
Dec 19, 2008
12:00 AM
Question: When using an FPGA on a PCB for serial programming of the CY22150, during write mode, the device will respond with an ACK pulse after eight bits by pulling the SDAT line low. Is this a 'weak 0', or a 'strong 0'? Can there be a conflict with the I/O of the FPGA?
Answer:
When the CY22150 sends an ACK, it is a strong zero.
- clock generation
Rate this article:
Contributors
This widget could not be displayed.Anonymous
