- Mark as Read
- Printer Friendly Page
Power MOSFET - FAQs
How do you measure RJC thermal resistance?
We measure the junction of the die to the edge of the package. For further information on thermal resistance, please refer to the document Thermal Resistance Theory and Practice:
https://www.infineon.com/dgdl/smdpack.pdf?fileId=db3a304330f6860601311905ea1d4599
How do you parallel MOSFETs in high current applications?
Here is Infineon's new application note detailing the importance of current balancing in high current applications:
https://www.infineon.com/dgdl/Infineon-PowerMOSFET_Paralleling_power_MOSFET_in_high_current_applicat...
How do you parallel MOSFETs in high current low voltage drive applications?
Here is Infineon's new application note explaining how to parallel MOSFETs in these applications:
https://www.infineon.com/dgdl/Infineon-ApplicationNote_MOSFET_Paralleling_MOSFETs_in_high-current_LV...
How to use gate charge to design the drive circuit of Power MOSFETs?
Check out this application note for details:
https://www.infineon.com/dgdl/Infineon-Use_Gate_Charge_to_Design_the_Gate_Drive_Circuit_for_Power_MO...
Where can I find more information on Infineon SPICE models?
You can find additional information in this app note:
https://www.infineon.com/dgdl/Infineon-ApplicationNote_PowerMOSFET_SimulationModels-AN-v01_00-EN.pdf...
What is single pulse avalanche in a MOSFET?
You can read all about avalanche in this app note:
https://www.infineon.com/dgdl/Infineon-ApplicationNote_Some_key_facts_about_avalanche-AN-v01_00-EN.p...
