Plug & Play LEDs with XDPL8219
IFX_Publisher2
1000 replies posted First like given 750 replies posted
XDPL8219 is the perfect match for the primary stage of a 2-stage modular system complying fully with IEE1789 requirements for flicker-free light. E.g. https://www.infineon.com/cms/en/product/evaluation-boards/ref_tw_ild8150e_60v_1a REF_TW_ILD8150E_60V_1A provides a very efficient solution for an easy implementation of a highly professional Tunable White LED driver. Based on the https://www.infineon.com/cms/en/product/power/lighting-ics/dc-dc-led-driver-ic/ild8150 ILD8150/E, it consists of two identical channels and one auxiliary supply with 3.3V.
https://www.infineon.com/cms/en/product/evaluation-boards/ref_tw_bcr601_55v_0.5a/?redirId=135774 REF_TW_BCR601_55V_0.5A  is Infineon’s tunable white application based on the two linear regulators https://www.infineon.com/cms/en/product/power/lighting-ics/linear-led-driver-ic/bcr601  BCR601 and <a https://www.infineon.com/cms/en/product/power/lighting-ics/linear-led-driver-ic/bcr602 BCR602. It enables a very efficient as well as cost-effective solution for TW LED drivers with the highest quality of light.
Find out more https://www.infineon.com/cms/en/applications/industrial/led-lighting/two-stage-led-driver-solution here.
