Pin Mapping Differences Between the EZ-BLE™ PRoC™ Evaluation Board (CYBLE-212020-EVAL) and the BLE Pioneer Kit (CY8CKIT-042-BLE) - KBA212838
Version: *A
Translation - Japanese: EZ-BLE™ PRoC™評価ボード(CYBLE-212020-EVAL) と BLEパイオニアキット(CY8CKIT-042-BLE) とのピンマッピングの違い - KBA212838 - Comm...
Question:
What are the differences between the pins exposed on J1 and J2 headers of the EZ-BLE PRoC Evaluation Board (CYBLE-212020-EVAL) and the pins expected by the J10 and J11 headers on the BLE Pioneer Kit (CY8CKIT-042-BLE)?
Answer:
Yes, there are differences between the pins exposed. The EZ-BLE PRoC Evaluation Board quick start guide explains how to use the board with the BLE Pioneer Kit and the differences in pin mapping. This is also explained below.
Figure 1 shows the J10 and J11 headers on the BLE Pioneer Kit.
Figure 1: J10 and J11 headers on BLE Pioneer Kit
The EZ-BLE PRoC Evaluation Board can be plugged on to these headers as shown in Figure 2.
Figure 2: EZ-BLE PRoC Evaluation Board plugged on BLE Pioneer Kit
Figure 3 shows the pinout and details of the EZ-BLE PRoC Evaluation Board (CYBLE-212020-EVAL), which is a fan-out board for EZ-BLE PRoC Modules (CYBLE-212020-01).
Figure 3: EZ-BLE PRoC Evaluation Board (CYBLE-212020-EVAL) Pinout
The EZ-BLE PRoC Module exposes a subset of the GPIOs that are expected on the BLE Pioneer Kit. Therefore, the evaluation board for the module has several pins that do not map to any port of the module. In addition, some pins exposed on the J1 and J2 headers of the evaluation board differ from the pins expected on the J10 and J11 headers of the BLE Pioneer Kit. A table showing the complete pin mapping and highlighting differences is shown below. The table specifies NC (No Connect) for the pins that are not available on the evaluation board.
CY8CKIT-042-BLE
J11 Header
CYBLE-212020-EVAL
J2 Header
CY8CKIT-042-BLE
J10 Header
CYBLE-212020-EVAL
J1 Header
VDDD
VDD*
VDDA
VDD*
VREF
VREF
VDDR
VDDR
XRES
XRES
GND
GND
GND
GND
GND
GND
P0_0
NC
P2_0
P2_0
P0_1
NC
P2_1
P0_5**
P0_2
NC
P2_2
P2_2
P0_3
NC
P2_3
P2_3
P0_4
NC
P2_4
P2_4
P0_5
NC
P2_5
P0_4**
P0_6
P0_6
P2_6
P2_6
P0_7
P0_7
P2_7
P3_5**
P1_0
P1_0
P3_0
NC
P1_1
NC
P3_1
NC
P1_2
NC
P3_2
P3_2
P1_3
NC
P3_3
P3_3
P1_4
P1_4
P3_4
P3_4
P1_5
P1_5
P3_5
P3_5
P1_6
P1_6
P3_6
P3_6
P1_7
P1_7
P3_7
P3_7
P4_0
NC***
P4_1
NC
P5_0
P5_0
P5_1
P5_1
*EZ-BLE PRoC Module shorts the digital and analog power rails of PRoC BLE (highlighted rows in blue)
**Pins differ from the pins expected on the BLE (highlighted rows in yellow)
***The EZ-BLE PRoC Module has the P4_0 pin however this is connected to the Cmod capacitor on the EZ-BLE PRoC Evaluation Board and is not exposed on the J1 header.
Note: The EZ-BLE PRoC Module is supported on PSoC® CreatorTM 3.3 SP2 and later versions. While the GPIOs available on the EZ-BLE PRoC Module and consequently on the EZ-BLE PRoC Evaluation Board are limited, every functionality available on a PRoC BLE silicon is available on the EZ-BLE PRoC Module. The only exception is the CapSense® Gestures Component that handles one- and two-finger gestures. This Component is not available on the EZ-BLE PRoC Module.
Applicable Kits:
PRoC BLE Modules
PSoC 4 BLE Modules
CYBLE-212020-EVAL
CY5671
CY5674
CY8CKIT-142
CY8CKIT-141
YES
NO
NO
NO
NO
Headers (on CYBLE-212020-EVAL): Usage description
Headers
Usage description
J3
It is used to short VDDD and VDDR.
Note: J3 can be ignored for usage if customers insert CYBLE-212020-EVAL into CY8CKIT-042-BLE since VDDD and VDDR are short in CY8CKIT-042-BLE. However, if customers use the CYBLE-212020-EVAL separately, customer need to short J3 based on application requirement.
J5
P5.0 and P5.1 are available for debug purposes (no jumper usage intended here).
J6
It is used to short P3.5 of CYBLE-212020-01 module to either/both of P3.5 and P2.7 of CY8CKIT-042-BLE.
Contributors
