Parameter tp in the data sheet of IPD50P04P4L
Infineon_Team
In the data sheet Page 4, diagram of “safe operation area”, the area below the curves represent the Safe operating area (I_D is a function of VDS) for a specific tp (the higher the current, the shorter the allowed time). Everything below the line is the SOA (however with the restriction that TC must remain within 25Grad). In general, the Ptot diagram can also be used to translate the characteristic curves in parallel if the value it needs is not present. The diagram is not valid for linear operation.
