Knowledge Base Articles
PSoC® Creator™ Auto-complete Does Not Work in PSoC 3 Projects with ISRs - KBA223190
chaitanyav_41
Version: **
Translation - Japanese: PSoC®Creator™のオートコンプリートがISRを含むPSoC 3プロジェクトで機能しない -KBA223190 - Community Translated (JA)
Question:
When I add ISR routines to a C file in my PSoC 3 project, the auto-complete feature fails to work. Why?
Answer:
PSoC Creator uses the Clang compiler to enable the auto-complete feature.
The Keil compiler uses non-standard C syntax for interrupts; this causes Clang to become corrupt. This error only affects PSoC 3 where Keil is used.
Workaround:
Move the CY_ISR to the bottom of the affected C files.
Example:
CY_ISR_PROTO(Interrupt_Handler);
CyGlobalIntEnable; /* Enable global interrupts. */
ISR_StartEx(Interrupt_Handler);
CY_ISR(Interrupt_Handler)
Version history
Revision #:
1 of 1
Last update:
‎Mar 15, 2018 07:27 AM
Updated by:
Contributors
