- Mark as Read
- Printer Friendly Page
PSoC™ 64: Provisioning and entrance exam procedures fail when VDDIO0 is 2.5 V - KBA234967
Community Translation: PSoC™ 64: VDDIO0が2.5Vの場合、プロビジョニングと入口検査手順が失敗する - KBA234967
Version: **
The provisioning process injects secured assets such as keys and security policies into the PSoC™ 64 device. It involves the programming the eFuse memory, which require VDDIO0 to be at 2.5 V. See “Secure Boot” SDK user guide for information.
When using “CySecureTools”, even when VDDIO0 is at 2.5 V, if VTARG is not 2.5 V, the provisioning and entrance exam procedures fail with the following error:
ERROR: Silicon voltage is out of range. Expected voltage level is in range 2.25 V - 2.75 V. Check the log for details
This occurs because "CySecureTools” internally uses pyOCD, which reads only the VTARG voltage and not VDDIO0.
Note: You will observe this issue only when using “CySecureTools” for provisioning the PSoC™ 64 device.
Workaround:
First, try provisioning the device with both VTARG and VDDIO0 at 2.5 V and confirm that the provisioning is successful. If the provisioning succeeds, use one of the following workarounds:
Note: Provisioning requires the VDDIO0 voltage to be at 2.5 V ± 5%. Both these workarounds disable the target voltage check. So, when the voltage check is disabled, ensure that the VDDIO0 voltage is within range. Failing to do so may damage the device.
- Disable target voltage check during the entrance exam in the “CySecureTools” source.
For “CySecureTools” version 3.1.0, comment out the lines 62 to 70 in exam_mxs40v1.py located in <CySecureTools Install Directory>\execute\entrance_exam\.
<CySecureTools Install Directory> indicates the installation directory of “CySecureTools”.
For ModusToolbox™ 2.4, it is C:\Users\<user>\ModusToolbox\tools_2.4\python\Lib\site-packages\cysecuretools.
Figure 1: Comment out lines 62 to 70 in exam_mxs40v1.py
- Connect the VTARG pin of the programmer to 2.5 V or VDDIO0 of the target.
