PSoC™ 4 HVPA: Current measurement range with different shunt resistance - KBA236359
Infineon_Team
Version: *A
The current measurement range (
IRMEAS) with PSoC™ 4 HVPA devices is defined as ±3000 A when the shunt resistance (RSENSE) is 100 μΩ [SID104]. IRMEAS with different RSENSE value is calculated as follows:
There are two cases depending on the Programmble gain value (GPGA). Analog gain (GANA) becomes GANA = GPGA /4.
  1. GPGA ≤ 16
PSoCTM 4 HVPA devices specify RSHx and RSLx differential input voltage range = ±0.3 V [SID114]. Therefore, if you change the resistance value, the following formula must be satisfied:
IRMEAS = 0.3 V / RSENSE
  1. GPGA 32
In this case, the input signal drops below the internal reference voltage of 1.2 V if the following formula is satisfied:
IRMEAS_GPGA = 1.2 / (RSENSE × GANA)
From 1 and 2, Table 1 shows an example of the current measurement range (IRMEAS).
Table 1  Current measurement range
Measurement range
GPGA
RSENSE
25 μΩ
50 μΩ
100 μΩ
200 μΩ
IRMEAS_G4
4
±12000 A
±6000 A
±3000 A
±1500 A
IRMEAS_G8
8
±12000 A
±6000 A
±3000 A
±1500 A
IRMEAS_G16
16
±12000 A
±6000 A
±3000 A
±1500 A
IRMEAS_G32
32
±6000 A
±3000 A
±1500 A
±750 A
IRMEAS_G64
64
±3000 A
±1500 A
±750 A
±375 A
IRMEAS_G128
128
±1500 A
±750 A
±375 A
±187.5 A
IRMEAS_G256
256
±750 A
±375 A
±187.5 A
±93.75 A
IRMEAS_G512
512
±375 A
±187.5 A
±93.75 A
±46.875 A
Note: This KBA applies to the following series of PSoC™ 4 HV family MCUs:
  • PSoC™ 4 HVPA series
Contributors
