PSoC® 4 Analog Routing – KBA96941
Version: **
Question: Where can I view and edit PSoC 4 analog routing in PSoC Creator™?
Answer:
You can view the analog routing of a schematic by opening the design wide resources (cydwr) window in PSoC Creator and selecting the “Analog” tab as Figure 1 shows.
Figure 1. Opening the Analog Viewer
You should build the project to view how your schematic is mapped to the analog resources inside PSoC. Figure 2 shows an example schematic and the corresponding analog routing.
Figure 2. Example Routing
Schematic
Routing
You can also edit the Component-to-resource mapping in this window. For example, if you want to relocate an Opamp, right-click the Opamp, select “Relocate,” and then select the desired location, as Figure 3 shows.
Figure 3. Relocating a Component
Contributors
