PSoC 3/5 Del-Sig ADC Resolution and Sample Rate
KannanS_06
First like received
Question: How does the resolution of the PSoC 3/5 Del-Sig ADC affect the sampling rate?
Answer:
Changing the Del-Sig ADC resolution directly affects the maximum/minimum sample rates possible in the ADC. The higher the resolution, the lower is the sample rate.
The following table lists the maximum and minimum sample rate for different resolutions of the ADC.
     Resolution
     Maximum Sample rate
     Minimum sample rate
     20 bit
     187sps
     8sps
     16 bit
     48ksps
     2ksps
     12 bit
     192ksps
     4ksps
     8 bit
     384ksps
     8ksps
Contributors
