PCM Sound Source Input in Traveo S6J3200 Series MCUs - KBA226513
01:11 AM
- Mark as Read
- Printer Friendly Page
Feb 27, 2019
01:11 AM
Question:
Are both 8-bit and 16-bit PCM sound source inputs supported in Traveo™ S6J3200 series MCUs?
Answer:8-bit Pulse Code Modulation (PCM) sound source is not supported. 16-bit and 32-bit PCM sound source inputs are supported. For details, see the "Sound Waveform Generator" section in 32-bit Microcontroller Traveo™ Family S6J3200 Series Hardware Manual.
Labels
Rate this article:
