OTA2 Reliability for Battery-operated Wireless Devices - KBA231150
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Version: **
Translation - Japanese: バッテリー駆動のワイヤレスデバイスのOTA2信頼性 - KBA231150 - Community Translated (JA)
To guarantee a reliable OTA2 operation for battery-operated wireless devices such as CYW43907 and CYW54907, it is recommended to check the battery level before executing the OTA2 extract operation.
In /43xxx_Wi-Fi/apps/snip/ota2_extract/ota2_extract.c, the CHECK_BATTERY_LEVEL_BEFORE_OTA2_UPGRADE macro instructs the function to ensure that the battery level is checked before calling the OTA2 extract function. The battery level is checked using the platform_check_battery_level(CHECK_BATTERY_LEVEL_OTA2_UPGRADE_MINIMUM) function. You should customize this function according to your battery circuit design. It contains function calls to measure the battery level.
CHECK_BATTERY_LEVEL_OTA2_UPGRADE_MINIMUM is a user-defined constant which indicates the minimum battery level necessary to perform an OTA2 operation. If the measured battery level is below this value, the platform_check_battery_level() function will return an error; the OTA2 extract operation will not proceed. The CHECK_BATTERY_LEVEL_BEFORE_OTA2_UPGRADE macro can be defined in wiced_defaults.h to enable this feature.
The code snippet of ota2_extract.c is shown below. The macros and functions used for checking the battery-level are highlighted.
void application_start( )
    wiced_result_t              result;
    extractor_extract_result_t  extract_result;
    platform_dct_ota2_config_t  dct_ota2_config;
     * Initially:
     * We don't use the normal wiced_init(), as we don't want wiced_wlan_connectivity_init( ); unless we are running SoftAP
     * We don't use wiced_core_init(), as we don't want to use wiced_platform_init( ), as the filesystem may be invalid, and we don't want to assert
platform_init_external_devices();
    /* initialize DCT mutex */
wiced_dct_init();
OTA2_EXTRACT_PRINTF(("\r\nHi, I'm the OTA2 extraction app (ota2_extract).\r\n"));
    extract_result = EXTRACT_RESULT_OK;
    if ( ota2_extract_check_battery_level() != WICED_SUCCESS)
        extract_result = EXTRACT_RESULT_ERROR_BATTERY_LOW;
The function definition of ota2_extract_check_battery_level() is shown below (also in ota2_extract.c😞
/* Returns WICED_ERROR if battery level considered too low */
wiced_result_t ota2_extract_check_battery_level( void )
#ifdef CHECK_BATTERY_LEVEL_BEFORE_OTA2_UPGRADE
    /* check for battery level before doing large amount of writing */
    if (platform_check_battery_level(CHECK_BATTERY_LEVEL_OTA2_UPGRADE_MINIMUM) != WICED_SUCCESS)
        /* check_battery_level() failed */
        return WICED_ERROR
#endif /* CHECK_BATTERY_LEVEL_BEFORE_OTA2_UPGRADE */
    return WICED_SUCCESS;
Contributors
