Knowledge Base Articles
Number of Programming times of CY2071A and CY2071AF
Question: How many times is it possible to reprogram the CY2071A and CY2071AF devices?
Answer:
The CY2071A (Factory Programmed device) and CY2071AF (Field Programmable Device) are one time programmable devices since they are EPROM based and cannot be re-programmed in the field. There is no known way to erase a CY2071AF device by doing in-circuit or functional testing.
Version history
Revision #:
1 of 1
Last update:
‎Dec 19, 2008 12:00 AM
Updated by:
Contributors
