Motivation for the 1200V CoolSiC™ Schottky diode G5
Infineon_Team
- Easy plug and play with silicon diodes.
- For some high efficiency & high output power required applications that need to operate in high pollution design environment e.g. EV DC charging.
- SiC diode with high creepage/clearance distances package (TO-247-2) is the ideal solution for designers.
