ModusToolbox 2.1: Unable to Create Project: TLS Initialization Failed Error on Ubuntu 20.04 - KBA230375
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Author: DheerajK_81           Version: **
Translation - Japanese: ModusToolbox 2.1: プロジェクトを作成できない: Ubuntu 20.04でのTLS初期化失敗エラー – KBA230375 - Community Translated (JA)
Question:
When I try to create a project in ModusToolbox 2.1 on Ubuntu 20.04, the Project Creator fails with the following error:
“Checking if remote manifest is accessible...
Failed to access remote server: Download of https://github.com/cypresssemiconductorco/mtb-super-manifest/raw/v2.X/mtb-super-manifest.xml failed: TLS initialization failed
No internet connection found and offline content is not available. Check the user guide to see how to get offline contents.
Press "Retry" to try again”
Answer:
The problem occurs because Ubuntu 20.04 does not include the libssl1.0.0 package, the part of OpenSSL which supports TLS. Do the following to install it manually:
1. Create a file called  bionic.list in your home directory with the following contents. Save and close.
deb http://archive.ubuntu.com/ubuntu bionic main
deb http://archive.ubuntu.com/ubuntu bionic-updates main
deb http://security.ubuntu.com/ubuntu bionic-security main
2. Copy the file to /etc/apt/sources.list.d/:
sudo cp bionic.list /etc/apt/sources.list.d/
3. Perform the update and install the libssl1.0.0 package:
apt-get update
apt-get install libssl1.0.0
4. Ensure that you have Git installed and ran the scripts as described in README_2.1.txt in ModusToolbox.
Contributors
