Meaning of Wakeup Pulse Filter Constant in S6BT112A - KBA228428
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Author: AtsushiT_61           Version: **
Translation - Japanese: S6BT112Aのウェイクアップ パルス フィルター定数の意味 - KBA228428 -
Question:
What is the meaning of the wakeup pulse filter constant in S6BT112A?
Answer:
At the Master Node: In the wakeup pulse of the Sleep mode, the transceiver is designed so that a low pulse less than the Trx_wakeup_master value input to the BUS pin is not output to the RXD pin. The RXD pin waveform is delayed by 30 to 150 us with respect to the bus waveform.
At the Slave Node: In the wakeup pulse of the Sleep mode, the transceiver is designed so that a low pulse less than the Trx_wakeup_slave value input to the BUS pin is not output to the CLK pin. The CLK pin waveform is delayed by 0.5 to 5 us with respect to the bus waveform.
Table 1 lists the wakeup pulse filter constant and Figure 1 shows the filtered waveforms at wakeup. For more details, see Table 8-7. AC Characteristics in the S6BT112A datasheet.
Table 1. Wakeup Pulse Filter Constant
Parameters
Symbol
Pin Name
Conditions
Min
Typ
Max
Unit
Wakeup pulse filter constant (Master)
Trx_wakeup_master
BUS
NSLP = 0 V
SELMS = 0 V
VTH(bus) = 42.3 %
30
150
us
Wakeup pulse filter constant (Slave)
Trx_wakeup_slave
BUS
NSLP = 0 V
SELMS = 5 V
VTH(bus) = 42.3 %
  1. 0.5
5
us
Figure 1. Filtered Waveforms at Wakeup
Contributors
