Mean Time to Failure Versus Mean Time Between Failure – KBA94271
- Mark as Read
- Printer Friendly Page
Version: *A
Translation - Japanese: 平均故障時間と平均故障間隔 - KBA94271 - Community Translated (JA)
Question: What is the difference between Mean Time to Failure (MTTF) and Mean Time Between Failure (MTBF)?
Answer:
The MTTF is the average, or mean, of the amount of time that a design or component is in operational condition. The MTBF is the average time between failures, including the average repair time.
In a lot of designs and components, the MTTF value is very similar to the MTBF value with MTBF being slightly greater than MTTF. This is because MTBF includes the repair time of the designs or components. If a design or component works for an extended time, then it fails, is repaired in a reasonable amount of time, and then once again works for an extended time, the MTTF is the average, or mean, of the amount of time that it is in operational condition. The MTBF is the average time between failures including the average repair time.
- 32-bit arma cortexa-m psoca
- aerospace & defense
- automotive
- clocks & buffers
- interface
- lighting & power control
- memories for embedded systems
- mtbf
- mttf
- proprietary 2.4 ghz rf
- quality
- touch sensing (capsense)
- usb controllers
This widget could not be displayed.Anonymous
