Maximum Junction Temperature and Power Consumption Calculator
05:41 AM
- Mark as Read
- Printer Friendly Page
May 05, 2011
05:41 AM
How to find the power consumption, maximum junction temperature and absolute maximum temperature of a memory part?
The power consumption and maximum junction temperature within the operating range can be calculated following the steps provided in Application note 'AN4017 – Understanding Temperature Specifications: An introduction'.
We have created a html tool for the same and are attached below. One is for Sync SRAMs and other one is for Async and nvSRAMs. You can use it to find Maximum Power Consumption and Maximum Junction Temperature for a Infineon SRAM part.
The following is the absolute maximum junction temperatures for the SRAM families:
Type of Memory device | Junction temperature |
Sync SRAM | 125°C |
Async SRAM | 150°C |
nvSRAM | 150°C |
FRAM | 125°C |
Labels
- 1 mb quad spi nvsram
- 16mb nvsram- replacement for battery-backed sram and mram
- 4 mb f-ram
- AN4017
- async fast srams
- f-ram parallel
- f-ram processor companion
- f-ram serial
- Maximum Junction Temperature
- nonvolatile ram
- nvsram parallel
- nvsram serial
- Power Consumption Calculator
- sram
- synchronous srams
Rate this article:
