Manually Install the Prerequisites and Drivers for ModusToolbox™ (Windows)
Charles_Lai
250 sign-ins 10 likes given 10 questions asked
ModusToolbox™ software requires some drivers and prerequisites to be installed on your Windows OS.
They come together with the ModusToolbox™ installer and will be installed during the installation process.
However, sometimes they might fail to be unattendedly installed due to the lack of privileges in certain environments.
In such cases, you can install them manually, try to grant them enough permissions, and see if they can be installed.
Install the Drivers for ModusToolbox™
  1. Download the attachment to your PC and unzip it.
  2. Run the file "mtb_drivers_installer.exe" as administrator.Charles_Lai_1-1686895702053.png
  3. Finish the process followed without errors to ensure the drivers are installed.
  4. Now the USB drivers for KitProg, MiniProg, Jtag, CyUSBSerial, and other devices are installed on your PC.
Install the Prerequisites for ModusToolbox™
  2. Run the file "mtb_prereq_installer.exe" as administrator.Charles_Lai_2-1686896061982.png
  3. Finish the process followed without errors to ensure the prerequisites are installed.
  4. Now the required VC++ redistributables are installed on your PC.
