‘Make Getlibs’ Command Fails with a Syntax Error in ModusToolbox - KBA229440
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Author: DheerajK_81           Version: **
Translation - Japanese: ‘Make Getlibs’ Command Fails with a Syntax Error in ModusToolbox - Community Translated (JA)
With ModusToolbox™ 2.0 on Windows, application creation fails with a syntax error like this:
/bin/bash: -c: line 0: syntax error near unexpected token `('
This syntax error occurs if the PATH system environment variable has non-standard symbols.
Ensure that the PATH variable does not contain any control characters or any of the following characters:
  • forward slash ( / )
  • less than ( < )
  • greater than ( > )
  • vertical bar or pipe ( | )
  • double quote ( “ )
Remove anything that isn’t an actual path. Restart ModusToolbox for the changes to take effect.
For a real-world example of this problem, see the “getlibs failed” thread in Cypress Community.
Contributors
