MS2GO Demo board programming based on Dave with printf output.
Neo_Lu
50 replies posted 5 likes given 100 sign-ins
In the magnetic sensor development tool, Infineon provides complete supporting software and source code based on Arduino platform; However, this article summarizes the usage of MS2GO EVM board based on Dave IDE, and provides the method of using printf() function to output in the console column.
Part 1: How to use printf() in console?
Step 1: Debug -> Debug Configuration -> Startup, as shown in picture;
Step 2: Project Properties -> c/c++ Build -> Settings -> ARM GCC C Linker -> Miscellaneous -> Other Flags add
"-specs=rdimon.specs" -> Save;
Step 3:  Add "initialise_monitor_handles();" into the main().
        printf(...);
 Part 2: The source code of MS2GO for DAVE
The source code is attached and can output data in LSB form, the way to translate data into real value we need can be found in datasheet,
