MOTIX™ 6EDL7141: Register mapping in BPA Motor Control GUI - KBA236258
Infineon_Team
Version: **
Context:
The MOTIX™ 6EDL7141 registers’ values can be changed via battery-powered application (BPA) motor control GUI or DAVE project (6EDL7141_SPILIB_XMC1400). The final released firmware will be based on ModusToolbox™, but for this SPILIB demonstration, it’s based on DAVE IDE. BPA motor control GUI is a graphical interface for evaluation boards 6EDL7141 (EVAL_6EDL7141_TRAP_1SH) and IMD700A (EVAL_IMD700A_FOC_3SH). This GUI provides easy access to play around with the MOTIX™ 6EDL7141 registers for users. A brief relation between the MOTIX™ 6EDL7141 registers and the BPA motor control GUI is shown in the below table.
Workaround:
The 6EDL7141 smart gate driver software features are divided into four categories:
  1. Power supply
  2. PWM and three-phase gate driver
  3. Current sense amplifier and over-current protection (OCP)
  4. Housekeeping
1   Power supply
If PVCC set point is set to 15 V, Charge Pump Pre-charge is enabled, Buck Converter frequency is 500 kHz, DVDD soft start time is 500 us, DVDD TurnOn Delay is 600 us and DVDD OCP threshold is 300 mA then Supply configuration register (SUPPLY_CFG) is 1 10 0 xx 0100 01 xx 01. If Charge Pump Clock Frequency is 390.625 kHz and Charge Pump Spread Spectrum is enabled then Charge Pump Configuration is (CP_CFG) is 0000000000000 0 01.
Software Feature
BPA GUI Setting
6EDL7141 Register Bitfield
Condition
6EDL7141 Register Setting
Power Supply
SUPPLY_CFG
x xx x xx xxxx xx xx 01
PVCC (15V) (01) (PVCC_SETPT)
SUPPLY_CFG
CP_CFG
0000000000000 0 01
CP_CFG
0000000000000 x 01
Charge Pump Clk Frq (CP_CLK_CFG) (390.625 kHz)
CP_CFG
0000000000000 0 xx
Charge Pump Spread Spectrum (CP_CLK_SS_DIS) (En)
SUPPLY_CFG
1 xx x xx xxxx xx xx xx
Charge Pump Pre-charge (CP_PRECHARGE_EN) (En)
SUPPLY_CFG
x xx 0 xx xxxx xx xx xx
Buck converter frq (BK_FREQ) (500kHz)
SUPPLY_CFG
x xx x xx 0100 xx xx xx
DVDD Soft Start Time (DVDD_SFTSTRT) (500us)
SUPPLY_CFG
x 10 x xx xxxx xx xx xx
DVDD Turn On Delay (DVDD_TON_DELAY) (600us)
SUPPLY_CFG
x xx x xx xxxx 01 xx xx
DVDD OCP Thd (DVDD_OCP_CFG) (300mA)
If PWM Mode is 1 PWM with Hall sensors mode, PWM Freewheeling Mode is Active FW, Brake configuration is High side brake and PWM alternate recirculation is enabled, then PWM configuration register (PWM_CFG) is
000000000 1 01 0 011. If Dead time rising is 520 ns and Dead time falling is 520 ns, then Dead time configuration register (DT_CFG) is 00000101 00000101. If High side source current is 200mA and High side sink current is 200mA, Low side source current is 200mA and Low side sink current is 200mA, then Current Drive Configuration (IDRIVE_CFG) is 1011 1011 1011 1011. If Pre-charge source current is 200mA and Pre-charge sink current is 200mA, and Pre-charge is enabled, then Current Drive Pre-Configuration (IDRIVE_PRE_CFG) is 0000000 0 1011 1011. If Source and sink current time periods TDrive1, TDrive2, TDrive3, and TDrive4 are 100 ns, then Timing Drive Source Configuration (TDRIVE_SRC_CFG) is 00001010 00000110 and Timing Drive Sink Configuration (TDRIVE_SINK_CFG) is 00001010 00000110.
Software Feature
BPA GUI Setting
Condition
PWM & 3 Phase Gate Driver
PWM_CFG
000000000 x xx x 011
PWM_Mode (1PWM with Hall sensors) (011)
PWM_CFG
DT_CFG
00000101 00000101
IDRIVE_CFG
1011 1011 1011 1011
IDRIVE_PRE_CFG
0000000 0 1011 1011
TDRIVE_SRC_CFG
00001010 00000110
TDRIVE_SINK_CFG
00001010 00000110
PWM_CFG
000000000 x xx 0 xxx
PWM Freewheeling Mode (Active freewheeling)(PWM_FREEW_CFG) (0)
PWM_CFG
000000000 x 01 x xxx
Brake Configuration (BRAKE_CFG) (01)
PWM_CFG
000000000 1 xx x xxx
Alternate Recirculation (PWM_RECIRC) (1En)
DT_CFG
xxxxxxxx 00000101
DT_CFG
00000101 xxxxxxxx
Dead time rising (DT_RISE) (520ns)
Dead time falling (DT_FALL) (520ns)
IDRIVE_CFG
xxxx xxxx xxxx 1011
IDRIVE_CFG
xxxx xxxx 1011 xxxx
(IHS_SRC) (200mA)
(IHS_SINK) (200mA)
IDRIVE_CFG
xxxx 1011 xxxx xxxx
IDRIVE_CFG
1011 xxxx xxxx xxxx
(ILS_SRC) (200mA)
(ILS_SINK) (200mA)
IDRIVE_PRE_CFG
0000000 x xxxx 1011
IDRIVE_PRE_CFG
0000000 x 1011 xxxx
Pre-charge source current (I_PRE_SRC) (200mA)
Pre-charge sink current (I_PRE_SINK) (200mA)
IDRIVE_PRE_CFG
0000000 0 xxxx xxxx
Pre-charge (I_PRE_EN) (0)(En)
TDRIVE_SRC_CFG
xxxxxxxx 00000110
TDRIVE_SRC_CFG
00001010 xxxxxxxx
TDRIVE_SINK_CFG
xxxxxxxx 00000110
TDRIVE_SINK_CFG
00001010 xxxxxxxx
TDRIVE1 (100ns)
TDRIVE2 (100ns)
TDRIVE3 (100ns)
TDRIVE4(100ns)
If Current Sense Amplifier B is enabled, Current sense gain of 8x via register pin, Blanking time of 100 ns, DC calibration is disabled, OCP deglitch time of 4 us, and OCP fault trigger is 16 OCP events, then Current Sense Amplifier Configuration (CSAMP_CFG) is
01 10 0 0010 010 0 001. If Current Sensing Mode is Shunt Resistor sensing, External Offset is disabled, Amplifier Auto Zero configuration is internally triggered, OCP positive threshold is 200 mV, OCP negative threshold is 200 mV, PWM Truncation is enabled, OCP fault latching is enabled, Brake on OCP is disabled, and Negative OCP is enabled, then Current Sense Amplifier Configuration 2 (CSAMP_CFG2) is 00 0 0 00 0 0 1 0011 0011. If Amplifier Timing Mode is Low Switches High, then Sensor Configuration (SENSOR_CFG) is 000000000 00 x xxxx. If Internal Offset of 5/12 DVDD is selected, then Supply Configuration register (SUPPLY_CFG) is x xx x xx xxxx xx 01 xx.
Software Feature
BPA GUI Setting
Condition
Current Sense Amplifier & Over Current Protection
CSAMP_CFG
xx xx x xxxx 010 x xxx
Current sensing by the single shunt (phase B enabled) (010) (CS_EN)
CSAMP_CFG
CSAMP_CFG2
SENSOR_CFG
000000000 00 x xxxx
SUPPLY_CFG
CSAMP_CFG
xx xx x xxxx xxx 0 001
Gain 8x(001)(CS_GAIN) via register configuration(0)(CS_GAIN_ANA)
CSAMP_CFG2
xx x x xx x 0 x xxxx xxxx
Shunt resistor sensing (0)(CS_MODE)
SUPPLY_CFG
Internal Offset 5/12 DVDD(CS_REF_CFG)
CSAMP_CFG2
xx x 0 xx x x x xxxx xxxx
Use External Offset (Disable)
SENSOR_CFG
000000000 00 x xxxx
Amplifier Timing Mode(CS_TMODE)
CSAMP_CFG
xx xx x 0010 xxx x xxx
Blanking time (CS_BLANK) of 100ns (0010)
DC calibration is not enabled from BPA GUI
CSAMP_CFG
xx xx 0 xxxx xxx x xxx
No DC calibration (CS_EN_DCCAL)(0)
CSAMP_CFG2
00 x x xx x x x xxxx xxxx
Amplifier Auto zero config.(CS_AZ_CFG)(Int.)
CSAMP_CFG2
xx x x xx x x x 0011 0011
OCP Positive Thd(200mV)(CS_OCP_PTHR), OCP Negative Thd(-200mV)(CS_OCP_NTHR)
CSAMP_CFG2
xx x x 00 x x x xxxx xxxx
PWM Truncation(CS_TRUNC_DIS)
CSAMP_CFG
xx 10 x xxxx xxx x xxx
OCP deglitch time(CS_OCP_DEGLITCH) 4us (10)
CSAMP_CFG
01 xx x xxxx xxx x xxx
OCP fault trigger(CS_OCPFLT_CFG) 16 OCP events (01)
CSAMP_CFG2
xx x x xx x x 1 xxxx xxxx
OCP fault latching(CS_OCP_LATCH)
CSAMP_CFG2
xx x x xx 0 x x xxxx xxxx
Brake on OCP(CS_OCP_BRAKE)
CSAMP_CFG2
xx 0 x xx x x x xxxx xxxx
Negative OCP(CS_NEG_OCP_DIS)
Housekeeping
If Hall Sensor Deglitch time is 640 ns, Over-temperature Shutdown is enabled, then Sensor configuration register (SENSOR_CFG) is
000000000 xx 0 0001. If ADC measurement filter is 32 samples averaging filter and ADC PVDD measurement filter is 32 samples averaging filter, then ADC configuration register (ADC_CFG) is 00000000 00 10 x xx x. If Watch Dog timer is enabled, Watch Dog (WD) Input selection is VCCLS and VCCHS, WD Fault report is status+nFault, and WD period time is 100ms, then Watch Dog Configuration register (WD_CFG) is 0 1111101001 1 011 1. If Buck Converter WD is enabled, Rotor Lock detection time is 5s, Rotor Lock detection is enabled, WD fault latching is enabled, Brake on WD timer overflow is enabled, WD DVDD restart delay is 6 ms, WD DVDD Re-start Attempts is 2 attempts, then WD Configuration register 2 (WD_CFG2) is 000 0 100 1 1011 10 1 1.
Software Feature
BPA GUI Setting
Condition
Housekeeping
SENSOR_CFG
000000000 xx x 0001
Hall Sensor Deglitch Time (640 ns)(HALL_DEGLITCH)
SENSOR_CFG
000000000 xx 0 0001
ADC_CFG
WD_CFG
WD_CFG2
OTP_PROG
00000000000 1110 x
SENSOR_CFG
000000000 xx 0 xxxx
Over-temperature Shutdown (0 En)(OTS_DIS)
ADC_CFG
00000000 xx 10 x xx x
ADC_CFG
00000000 00 xx x xx x
ADC Measurement filter (ADC_FILT_CFG) (32 samples averaging filter)
ADC PVDD Measurement Filter(ADC_FILT_CFG_PVDD) (32 samples)
WD_CFG
0 xxxxxxxxxx x xxx 1
WD_CFG
0 xxxxxxxxxx x 011 x
WD_CFG
0 xxxxxxxxxx 1 xxx x
WD_CFG
0 1111101001 x xxx x
Watch Dog Timer (WD_EN)(1 En)
WD Input Selection (WD_INSEL) (VCCLS and VCCHS)
WD Fault Report (WD_FLTCFG)(status register and pull down of nFAULT pin)
WD Period Time (WD_TIMER_T) (100ms 1001)
WD_CFG2
000 0 xxx x xxxx xx x x
WD_CFG2
000 x 100 x xxxx xx x x
WD_CFG2
000 x xxx 1 xxxx xx x x
Buck converter watchdog (WD_BK_DIS)(0 En)
Rotor lock detection time (WD_RLOCK_T)(5s)
Rotor lock detection (WD_RLOCK_EN)(1En)
WD_CFG2
000 x xxx x xxxx xx 1 x
WD_CFG2
000 x xxx x xxxx xx x 1
WD_CFG2
000 x xxx x 1011 xx x x
WD_CFG2
000 x xxx x xxxx 10 x x
WD Fault Latching (WD_EN_LATCH) (1 Flt Latched)
Brake on WD timer overflow (WD_BRAKE)(1)
WD DVDD restart delay (WD_DVDD_RSTSRT_DLY)(6 ms)
WD DVDD Re-start Attempts (WD_DVDD_RSTSRT_ATT)(2 attempts)
OTP_PROG
00000000000 1110 x
User ID (USER_ID) (14)
For more information on Registers of 6EDL7141 and BPA GUI, see 6EDL7141 DataSheet. Underlined ones are the bit changes in the register for that particular condition.
