Land Patterns for Analog IC - KBA224057
Community-Team
50 questions asked 10 questions asked 5 questions asked
Version: **
Translation - Japanese: アナログICのためのランドパターン - KBA224057 - Community Translated (JA)
Question:
Do you have a recommended land pattern for Analog ICs?
Answer:
Figure 1 through Figure 6 show the applicable PCB land pattern recommendations for WNO028, U4D020, SOF014, SOB008, STA008, and STI024 packages.
Table 1. List of PCB Land Patterns for ANALOG ICs
PN
PKG
PKG code
CY39C031
QFN028
WNO028
CY39C326
WLCSP020
U4D020
CY39C603
SOP014
SOF014
CY39C604
SOP008
SOB008
CY39C605
SOP008
SOB008
CY88151A
SOP008
SOB008
CY88152A
SOP008
SOB008
CY88154A
SOP008
SOB008
CY88155
TSSOP008
STA008
S6AP111A28
TSSOP024
STI024
Note: The values are reference values and do not guarantee the mounting yield and the mounting reliability.
Figure 1. WNO028 Recommended Land Pattern
Figure 2. U4D020 Recommended Land Pattern
For SMD, it is recommended that the post diameter be the same as the resist opening diameter. For NSMD, it is recommended that the post diameter be the same as the land diameter.
Figure 3. SOF014 Recommended Land Pattern
Figure 4. SOB008 Recommended Land Pattern
Figure 5. STA008 Recommended Land Pattern
Figure 6. STI024 Recommended Land Pattern
Contributors
