LITIX™: How to avoid current spikes when the load changes
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Community Translation: LITIX™: 負荷が変化した時の電流スパイクを回避する方法
Current spikes, which are created when the load of a current controlled LED driver changes, can be avoided by adding some external components. Take a look at https://www.infineon.com/dgdl/Infineon-atv_12v_LED_lighting_full-bridge_controller_TLD5190_V3-Simula... this simulation model, where you can check the effectiveness of this circuitry by yourself.
