Key features of BGAx1A10
Infineon_Team
BGAx1A10 is a high-gain LTE LNA family designed to improve data rates significantly. It includes an integrated gain control and bypass function that offers higher flexibility in the front end. In high gain mode, the BGAU1A10 offers the best Noise figure to ensure high data rates even on the LTE cell edge. Closer to the base station the bypass mode can be activated reducing current consumption. Thanks to the MIPI control interface, control lines are reduced to a minimum.
