Issue with Cypress Programmer 4.2 on Ubuntu – KBA237970
Infineon_Team
Problem:
Cypress Programmer 4.2 cannot be launched on a clean install of Ubuntu for all supported versions.
Background:
Previous versions of Cypress Programmer 3.0/4.0/4.1 launch correctly on clean Ubuntu installations.
This issue appeared after migration from Qt 5.10, to Qt 5.15, which requires libxcb 1.11 to be installed (https://doc.qt.io/qt-5/linux-requirements.html). The required package libxcb-xinerama0 is missing.
Solution:
Run the following command to install the prerequisite package:
sudo apt install libxcb-xinerama0
