Knowledge Base Articles
Is there a drop in replacement for the Cy7B923/933 LMB military package
Question: 1)Is there a drop in replacement for the Cy7B923/933 LMB military package? 2)Can I replace the Cy7B923/933-LMB with a -JC or -JI?
Answer:
Although the -LMB package is leadless chip carrier, the contact points for the package are spaced in such a way that the -JC or -JI packages can use the same PCB layout, and thus become drop-in replacements for the -LMB packages.
Please be noted the Temperature grades are different.
Version history
Revision #:
1 of 1
Last update:
‎Dec 19, 2008 12:00 AM
Updated by:
Contributors
