Is command line programming possible for TLD7002-16ES?
Bashar
5 questions asked 10 sign-ins 5 sign-ins
Send serial data with Byte data [6] ={0x55,0x04} format via serial COM port, reply message will be received via serial COM port when you send the read messageYou don’t need to upgrade the firmware of OTP programmer board. It is always good to have the latest OTP wizard and OTP firmware.
Contributors
