Knowledge Base Articles
Interfacing an I2C based temperature sensor, LM75 to PSoC 1
Question: How to Interface an I2C based temperature sensor, LM75 to PSoC 1 ?
Answer:
LM75 is a digital emperature sensor which has I2C interface feature. This sensor can be easily interfaced to PSoC 1 for temperature measurement.
I2CHW User Module in PSoC 1 can be used for this purpose. This module acts as I2C master and communicates with the slave I2C device, which is the sensor here.
A PSoC Designer project in which this is implemented is attached along with a document which explains the implementation.
Version history
Revision #:
1 of 1
Last update:
‎Mar 23, 2012 07:02 AM
Updated by:
Contributors
