Integrating I2C module on AURIX™ TC23x, TC22x, and TC21x - KBA234364
Dec 16, 2021
05:51 AM
- Mark as Read
- Printer Friendly Page
Dec 16, 2021
05:51 AM
Community Translation: AURIX™ TC23x、TC22x、および TC21xへのI2Cモジュールの統合– KBA234364
Version: **
Question: How to integrate an I2C module for the AURIX™ TC2xx series MCUs. Is there a possibility to do so?
Answer: The AURIX™ TC2xx series MCUs do not have dedicated I2C modules. However, you can emulate an I2C interface with the help of bit banging. To do so, use the CPU to generate the protocol with the required data to send and send it through the Timer Output Module (TOM) channels.
See the “Timer Output Module (TOM)” sections of the user’s manual for more information.
Note: This KBA applies to the following series of AURIX™ MCUs:
- AURIX™ TC2xx series
Labels
Rate this article:
