- Mark as Read
- Printer Friendly Page
Install CySecureTools via pip on macOS Big Sur - KBA233000
Version:**
Question:
Why do I get an exception error while trying to install CySecureTools on macOS?
distutils.errors.DistutilsError: Setup script exited with error: SandboxViolation:
mkdir('/private/var/root/Library/Caches/com.apple.python/private/tmp/easy_install- y8c1npmz', 511) {}
The package setup script has attempted to modify files on your system
that are not within the EasyInstall build area, and has been aborted.
This package cannot be safely installed by EasyInstall, and may not
support alternate installation locations even if you run its setup
script by hand. Please inform the package's author and the EasyInstall
maintainers to find out if a fix or workaround is available.
Answer:
This is likely caused by an outdated pip package. To resolve this issue, upgrade pip using the following command in a command-line terminal:
python3 -m pip install --upgrade pip
