Input signal needed to be sure 2EDN output goes HIGH/LOW
Infineon_Team
2EDN has LV-TTL thresholds for logic decision. Please use max. and min. values to get proper functionality. LV-TTL means low voltage two transistor levels. This is independent to power supply VDD.
For input voltage levels higher than 5V, a resistive voltage divider brings timings back to the symmetric slope rate between high and low.
