Infineon NOR Flash Replacement Parts
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Community Translation: インフィニオンNORフラッシュ代替品
This article https://community.infineon.com/t5/Knowledge-Base-Articles/Infineon-NOR-Flash-Replacement-Parts-KBA23... here contains a list of Infineon NOR Flash Memory families which can be used as a replacement for older/obsoleted Infineon NOR Flash Memory families. It also contains the links for the available migration guide application notes. For those replacements where a migration guide is not available, the table provides some comments highlighting the key differences between the two device families.
