- Mark as Read
- Printer Friendly Page
Infineon NOR Flash Replacement Parts – KBA233631
Community Translation: インフィニオンNORフラッシュ代替品 – KBA233631
Version: *A
Question: Please provide a list of the Infineon NOR Flash replacement parts.
Answer: This article contains a list of Infineon NOR Flash memory families which can be used as a replacement for older/obsoleted Infineon NOR Flash Memory families. It also contains the links for the available migration guide application notes. For those replacements where a migration guide is not available, this table provides some comments highlighting the key differences between the two device families.
Old MPN |
Replacement part MPN |
Comments |
S25FL-A |
S25FL-P |
Migration guide – AN201241 – S25FL-A to S25FL-P Migration Guide |
S25FL-P |
S25FL-S |
Migration guide – AN98577 – Migration from FL-P to FL-S Family SPI Interface Flash Memories |
S70FL256P |
S25FL256S |
Migration guide – AN98592 – Migration from S70FL256P to S25FL256S |
S25FL128P S25FL129P |
S25FL128L |
Migration guide – AN221699 – Migration guide for S25FL128L from S25FL128P or S25FL129P Quad SPI |
S25FL-S |
S25FL-L |
Migration guide – AN218107 – Migration from S25FL-S to S25FL-L Serial NOR Flash Memory |
S25FL1-K |
S25FL064L |
Migration guide – AN217010 – Migrating from S25FL1-K Serial NOR Flash to S25FL064L Serial NOR Flash |
S25FL064P |
S25FL064L |
Migration guide – AN216999 – Migrating from S25FL064P Serial NOR Flash Products to S25FL064L Serial NOR Flash Products |
S25FL004K S25FL008K S25FL016K S25FL032K S25FL064K S25FL128K |
S25FL064L S25FL128L S25FL256L |
FL-K has 8-pin and 16-pin SOIC package options and -40 °C to +85 °C and -40° to +105°C temperature options. FL-L has 8-pin and 16-pin SOIC, 8-contact WSON, and 24-ball BGA package options; Industrial |
S25FL204K S25FL208K S25FL216K |
FL2-K has an 8-pin SOIC package option, with an industrial grade (-40 °C to +85 °C) temperature option. FL-L has 8-pin and 16-pin SOIC, 8-contact WSON, and 24-ball BGA package options; Industrial (-40 °C to +85 °C), Industrial Plus (-40 °C to 105 °C), Automotive Grade 3 (-40 °C to 85 °C), Automotive Grade 2 (-40 °C to +105 °C), and Automotive Grade 1 (-40 °C to +125 °C ) temperature options. |
GL-P GL-S |
GL-T |
Migration guide – AN202453 – Migration from GL-P and GL-S to GL-T Flash |
S29GL-N |
S29GL-P |
Migration guide – AN98498 – S29GL-N to S29GL-P migration |
S29AL032D |
S29GL032N S29JL032J |
Migration guide – AN98568 – Migrating from S29AL032D to S29GL032N and S29JL032J |
GL-N GL-P |
GL-S |
Migration guide – AN98586 – Migration from GL-N and GL-P to GL-S Flash |
GL064N |
GL064S |
Migration guide – AN220470 – Migration from GL064N to GL064S |
S29JL-H |
S29JL-J |
Migration guide – AN98587 – Migrating from S29JL-H (32-64 Mb) to S29JL-J |
S29AL-D |
S29AL-J |
Migration guide – AN198573 – Migration from AL-D to AL-J (8 – 16 Mb) |
S29GL01GR S29GL512R |
S29GL064S S29GL128S S29GL512S S29GL01GS S70GL02GS |
GL-R has x8 and x16 data width options, configured using BYTE# pin option; 56-pin TSOP and 64-ball BGA package options; Industrial grade (-40 °C to +85 °C) and extended commercial grade (0 °C to +85 °C) temperature options. GL-S has x16 data width option and no BYTE# pin option; 56-pin TSOP, 64-ball BGA and 56-ball BGA package options; Industrial grade (-40 °C to +85 °C), Industrial Plus grade (-40 °C to +105 °C), Automotive Grade 3 (-40 °C to +85 °C), and Automotive Grade 2 (-40 °C to +105 °C) temperature options. |
Am29LV010B |
S29AL008J |
Am29LV010B has x8 data width option and no BYTE# pin option; 32-pin TSOP and 32-pin PLCC package options; Commercial grade (0 °C to +70 °C), Industrial grade (-40 °C to +85 °C) and Extended grade (-55 °C to +125 °C) temperature options. AL-J has x8 and x16 data width options, configured using BYTE# pin option; 48-pin TSOP and 48-ball BGA package options; Industrial grade (-40 °C to +85 °C), Extended grade (-40 °C to +125 °C), Automotive Grade 3 (-40 °C to +85 °C) and Automotive Grade 1 (-40 °C to +125 °C) temperature options. |
For more detailed information related to AC/DC characteristics, command summary etc., refer to the device datasheets. Visit our web page to know more about Infineon NOR Flash memory.
For cross reference search, use the search tool present here.
