Industrial Operating Temperature for Cypress Flash Memory Products - KBA203662
Version: *B
Translation - Japanese: Cypress Flash Memory製品の産業用動作温度範囲 - KBA203662 - Community Translated (JA)
Question:
What is meant by Industrial Operating Temperature for Cypress Flash memory products?
Answer:
Industrial operating temperature options are available on selected Cypress Flash memory products. When industrial operating temperature is offered, it means that the part has undergone rigorous testing and is approved by Cypress for wide temperature ranges often encountered in industrial and military environments, for example, -40 deg C to +85 deg C. Other temperature references such as "Extended Range," "Commercial Range," and "Wireless Temperature" undergo similar testing and approvals. Consult a specific part's datasheet for more information.
Contributors
