In parking mode, is it required to supply PWM1/CRC to turn on the LS?
Infineon_Team
When using TLE956x parking mode, is it necessary to supply PWM1/CRC pin to turn on the low-side MOSFETS?
In parking mode, users don't need to supply PWM1/CRC to turn on the low-sides. Low-sides will be turned on when parking mode is enabled and device is in STOP or SLEEP mode.
