Answer:
In some versions of Windows which use a non-English default language, when adding the C compiler license, the check box for accepting the license is not shown in Tools->Options->Compiler. A workaround to this can be accomplished by editing the Windows registry in the following manner:
1. Open ?regedit? through Start-> run
2. Go through the registry tree to My Computer->HKEY_LOCAL_MACHINE->SOFTWARE->
Cypress Microsystems->PSoC Designer->AddIn->Compilers->IMAGECRAFT
3. In this folder, add a string value named COMPILER_LICENSE and then enter the compiler key as the Value data (xxxxxxx-xxxxxx)
