Knowledge Base Articles
ISR Failures during Flash 370 and Flash 370i Programming
Question: Why is ISR failing programming?
Answer:
The Flash JAM driver uses a high performance counter located on all PC motherboards, and assumes that it counts at a certain rate. However, if the counter does not perform to standards, about 1.2 million per second, there may be timing problems when programming these devices. The best thing to do is to perform the procedure on a different machine.
Please be noted our entire Cypress CPLD product are Obsolete and not recommended for new design and development. For more information on CPLD product, please visit our webpage: http://www.cypress.com/go/cpld
Version history
Revision #:
1 of 1
Last update:
‎Jan 01, 2012 04:42 PM
Updated by:
Contributors
