ICC Compiler Support for the strtol() Library Function – KBA88266
Version: **
Question: Does the ICC compiler support the strtol() library function?
Answer:
Yes, the ICC compiler supports the strtol() library function. The function strtol() prototype is declared in the stdlib.h file in the following manner:
long strtol(CONST char *, char **, int);
Refer to the C Language Compiler User Guide for details about this library function. This guide is available in the following path:
Help > Documentation > Compiler and Programming Documents
Contributors
