I AM USING A S25FL256S SPI FLASH FOR BOOT-UP CODE. THE SYSTEM BOOTSUP FINE FROM POWER-ON, BUT FAILS TO BOOT-UP FROM A WARM SYSTEM RESET. WHAT COULD BE WRONG?-KBA203745
11:36 PM
- Mark as Read
- Printer Friendly Page
Oct 15, 2015
11:36 PM
Version: *A
Translation - Japanese: 起動コードに S25FL256S SPIフラッシュを使用しています。電源投入からのシステム ブートアップは正常に起動しますが、ウォーム システム リセットからのブートに失敗します。何が間違っているので...
Question:
I am using a S25FL256S SPI Flash for boot-up code. The system boots-up fine from power-on, but fails to boot-up from a warm system reset. What could be wrong?
Answer:
Most likely you are using a S25FL256S SPI Flash without a reset input. You may have changed the EXTADD-Bit in the Bank Address Register to access the flash with 4-byte addresses during runtime. During a reset, the SPI Flash remains in the 4-byte address mode and the system tries to boot with 3 byte addresses which won't work. Therefore, you need to use a version of the SPI flash with a Reset input pin.
Labels
- a25l
- a25lq
- active low
- address
- adesto
- ale
- amic
- at25bcm
- at25df
- at25dl
- at25dn
- at25dq
- at25f
- at26df
- boot code
- boot code storage
- bulk
- bus
- byte mode
- ce
- chip
- cle
- clock
- competitor
- control signals
- cs
- cycle
- cypress flash memory products
- data
- datasheet
- delay
- dio
- en25b
- en25f
- en25p
- en25q
- en25qh
- enable
- eon
- es29lv
- esmt
- f25l
- f25s esi
- flash
- gd25q
- gigadevice
- gnd
- ground
- hardware reset
- hold
- interface
- io
- is25cq
- is25ld
- is25lq
- issi
- jr28f
- js28f
- jz58f
- k8a
- k8c
- k8d
- k8f
- k8p
- k8q
- latency
- m25p
- m25pe
- m25px
- m28w
- m29dw
- m29f
- m29w
- m36a
- m36l
- m36w
- m39l
- m58bw
- m58l
- m58w
- macronix
- micron
- mode
- mx25l
- mx25v
- n25q
- nor
- nor flash memory
- oe
- operation
- page
- pc28f
- peripheral
- pf38f
- pf48f
- pf58f
- power on state
- processor
- program
- pz28f
- rc28f
- rd48f
- re
- read
- reset
- s25fl016k spi
- s25fl064l
- s25fl116k
- s25fl127s
- s25fl128l
- s25fl132k
- s25fl164k
- s25fl256l
- s25fl256s
- s25fl512s
- s25fs064s
- s25fs128s
- s25fs256s
- s25fs512s
- s25fs512t
- s70fl01gs
- s70fs01gs
- samsung
- sck
- sclk
- sector erase
- serial
- serial peripheral interface
- simultaneous
- snor
- spi
- status
- storage
- system
- tc58nvg2s0hbai4
- te28f
- toshiba
- vcc
- vio
- voltage
- voltage levels
- vref
- vss
- w25q
- w25x
- winbond
- word mode
- wp
Rate this article:
Contributors
This widget could not be displayed.Anonymous
