HyperBus Interface Channel Selection – KBA223297
Community-Team
50 questions asked 10 questions asked 5 questions asked
Version: **
Translation - Japanese: ハイパーバスインターフェースチャネル選択 - KBA223297 - Community Translated (JA)
Question: In the S6J3200 SampleSW hyperbusi example, why is the HyperBus interface ch.0 type (HYPERBUSI0_Type) used for the GPOR register configuration when selecting ch.1?
Answer: HyerBus interface ch.0 (for MCU) and ch.1 (for Graphic) are assigned to the same GPIO pins. To select ch.0 or ch.1, the GPO bit of the HYPERBUSIn_GPOR register should be configured and only the HYPERBUSIn_GPOR register in HyperBus ch.0 is used. When you select HyperBus interface ch.1, the example uses HYPERBUSI0_Type to configure the GPOR register.
The bit and function for channel selection are as follows:
GPO[0]
Description
0
Select HyperBus Interface Ch. 0
1
Select HyperBus Interface Ch. 1
Notes:
  • GPO[1] in HYPERBUSIn_GPOR of HyperBus Interface Ch. 0 is not used.
  • GPO[1:0] in HYPERBUSIn_GPOR of HyperBus Interface Ch. 1, Ch.2 are not used.
  • If HyperBus Interface Ch.2 is used, the configuration of the GPO bit is unnecessary.
  1. Example.
            //Config HyperBus Ch.1
            Hyperbusi_Init(HYPERBUSI1_Type, &HyperbusiConf);
            Hyperbusi_SetGPOutput(HYPERBUSI0_Type, HyperbusiLowPolarity, HyperbusiHighPolarity);
For more information about the HyperBus Interface, refer to the S6J3200 Hardware Manual.
Contributors
