How to send ADV data by AIROC™ Bluetooth tool
Sven_Wang
50 solutions authored 25 solutions authored First question asked
1. Environment CY8CKIT-062S2-43012.
https://www.infineon.com/cms/cn/product/evaluation-boards/cy8ckit-062s2-43012/
2. Program the FW by the Cypress Programmer:
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.cypressprogrammer
3. Open AIROC Bluetooth Tool and connect the HCI UART:
https://www.infineon.com/cms/en/design-support/tools/utilities/wireless-connectivity/airoc-bluetooth...
(If there don’t have 2 uart ports, hold the Mode SELECT button and release after 5s, you need to select the smaller uart port for the HCI command test)
4. Test the HCI command was sent succeed
5. Disabled the Adv
6. Set the adv parameters:
7. Set the adv data:
02 01 06 BLE only
05 09 74 65 73 74 adv complete local name: test
https://www.bluetooth.com/specifications/specs/core-specification-supplement-11/
8. Start Adv
9. Then you can search an adv by The AIROC™ Bluetooth® Connect App
