How to select the proper Hall sensor for my application?
Infineon_Team
We provide a parameter table to select your product. Here you select the relevant parameters of your application and narrow down your choice according to your requirements.
Please check the below link:
https://www.infineon.com/cms/en/product/sensor/magnetic-position-sensor/hall-switch/#!products
