How to perform only High Side switching using BTN9960LV?
IFX_Publisher4
50 questions asked First comment on KBA First reply posted
To use the BTN9960LV as high side switch only (assuming only one control signal), you could connect IN and INH pin together . With both signals high, the device is turned on and activates the high side switch. When driving inductive loads , the body diode in the low side switch provides a discharge path.
Contributors
