How to install EZ-PD™ Host SDK, Version 3.4.0
DoubleCircle
5 replies posted 5 questions asked First solution authored
1Download ezpdhostsdk_3.4.0_Windows_x86-x64.exe from the website below
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.ezpdhostsdk?_ga=2.168985505.1863477919.1682...
  • After the installation program is run, a pop-up message is displayed indicating that some prerequisites are missing. You need to install three more software
  • The PSoC™ Creator/ PSoC™ Programmer/EZ-PD™ Configuration Utility of the corresponding version is the version used when SDK release. If the corresponding version is not available on the website, you can install a later version.
  • When installing Host SDK3.4, the version provided by PSoC™ Creator/ PSoC™ Programmer is the latest version, which can be recognized by EZ-PD™ Host SDK. The EZ-PD™ Host SDK3.4 installation package of the latest version 1.3.9 of the EZ-PD™ Configuration Utility cannot be recognized. After installing the historical version 1.3.6, the EZ-PD™ Host SDK installer works properly.
2Click on the URL below to install PSoC™ Programmer, version 3.29.1, with the default Settings.
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.psocprogrammer?_ga=2.55634348.608243667.168...
  • When the installation is complete, a web page is displayed, close it
3Click on the URL below to install EZ-PD™ Configuration Utility, version 1.3.6, with the default Settings.
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.ezpdconfigurationutility?_ga=2.256353548.60...
  • After the installation is complete, the system is displayed, close it
4Click on the URL below to install PSoC™ Creator, version 4.4, with the default Settings.
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.psoccreator
5After the above three are installed, run the installation program “ezpdhostsdk_3.4.0_Windows_x86-x64.exe”. The installation can proceed normally
  • That’s all
