How to detect the basic wake-up signal w/ TLE9351 CAN-FD transceiver
YasA
5 questions asked 5 sign-ins First question asked
CAN-FD transceiver can only detect Wake-Up Pattern (WUP). However, ‘short’ CAN activity filter time can be used to also detect basic wake-up signal in HS-CAN network
Specification and detection mechanism for basic wake-up signal
CAN transceiver is compliant to ISO 11898-5 and supporting the basic wake-up signal.
The below is a specification of basic wake-up signal in ISO 11898-5.
To detect the basic wake-up signal, one dominant signal is needed.
And, the filter time is also defined as below
TLE7251 CAN transceiver is supporting above basic wake-up signal and the wake-up filter time. So, if dominant signal >5us is received in low power mode, it is detected as a wake-up signal.
Specification and detection mechanism for WUP
TLE9351 CAN-FD transceiver is fully compliant to ISO 11898-2;2016 and supporting the WUP.
The below is a specification of WUP in ISO 11898-2;2016,
To detect the WUP, the signals of dominant -> recessive -> dominant is needed.
TLE9351 CAN-FD transceiver is supporting above WUP mechanism and both filter times. This means, the signal of dominant and recessive can be detected with only 1 bit(500kbps = 2us = 1bit > 1.8us).
In case of HS-CAN frame format of CBFF(Classical Base Frame Format), in order to detect a WUP, 2 frames are needed in theoretical worst case scenario as below
However, CAN-FD transceiver can be detected WUP within the 1 frame in real HS-CAN frame format.
Because absolutely there is dominant state of >1bit and recessive state of >1bit in the identifier field.
This means, in the real communication, stuff bit will be added when same bit state is sent consecutively 5bit as below,
Note : Even if communication bit rate is used w/ 2Mbps or 5Mbps, 500kbps is used in arbitration phase.
More information
  • ISO 11898-2;2016   (Link)
  • TLE9251xx   (Link)
  • TLE9252Vxx   (Link)
  • TLE9255Wxx   (Link)
  • TLE9351 series   (Link)
  • Lite SBC series   (Link)
  • Mid Range+ SBC series   (Link)
  • MCP SBC series   (Link)
