How to deal with UART received errors ORE, FRE, and PE for MM MCU - KBA226797
Community-Team
50 questions asked 10 questions asked 5 questions asked
Author: TakashiM_61          Version: **
Translation - Japanese: MM MCUのUART受信エラーORE、FRE、およびPEに対処する方法 - KBA226797 - Community Translated (JA)
Question:
How do you deal with the following UART received errors in MM MCU: Overrun error (ORE), Framing error (FRE), and Parity error (PE)?
Answer:
The Overrun error (ORE), Framing error (FRE), and Parity error (PE) are all UART received errors.
To clear these error flags, set the Received Error Clear (REC) bit in the Serial Status Register (SSR) to ‘1’.
Contributors
