How to configure and use BlueZ stack on AIROC™ CYW54591 – KBA237373
Tushar_b
100 replies posted First like given 25 solutions authored
Do the following to configure and initialize the BlueZ stack dependencies on the device:
1. Download the Jetson Nano Developer Kit SD card image from the Jetson Download Center webpage.
Figure 1 Jetson Nano Developer Kit SD card image download
2. Burn the image into SD card using a flashing tool such as Balena Etcher.
3. Create a directory named “firmware” under the /etc directory. For example:
$sudo mkdir /etc/firmware
4. Copy the CYW54591 HCD file (bcm43xx.hcd) to the /etc/firmware folder.
$sudo cp bcm43xx.hcd /etc/firmware
Contact the local FAE or Infineon support to get the latest .hcd file.
5. Download and install the BlueZ stack-related libraries and dependencies on NVIDIA Jetson Nano Developer Kit:
$cd ~
$wget http://www.kernel.org/pub/linux/bluetooth/bluez-5.37.tar.xz
$tar xvf bluez-5.37.tar.xz
$cd bluez-5.37
$sudo apt-get update
$sudo apt-get install -y libusb-dev libdbus-1-dev libglib2.0-dev libudev-dev libical-dev libreadline-dev
$ ./configure --enable-library
$ make
$ sudo make install
6. Run the following HCI commands to initialize the CYW54591 device and configure the BlueZ stack:
Attach a serial UART to the BT stack as a transport interface:
$ sudo hciattach /dev/ttyTHS2 bcm43xx 3000000 flow -t 20
Scan for Bluetooth connections using the hcitool utility:
$ hcitool scan
Configure the Bluetooth connection:
$ hciconfig -a hci0
