How to change the MAC Address of an Infineon CYWx WiFi Chip?
IFX_Publisher4
50 questions asked First comment on KBA First reply posted
You can change the MAC address directly in the nvram file. Locate the macaddr attribute and set it to the desired value. Then you have to repeat the driver bringup. You can also use wl wrvar macaddr=00:11:22:33:44:55.
Contributors
